baileyrhood90's avatar
Dec 05, 2018
Nighthawk M1 MR1100 Download Speeds
Hi all. I am trying to figure out how much room for improvement I have on my download speeds with my Nighthawk M1 running on AT&T network with unlimited data plan. I routinely get 70 to 80mbps, but I know it's possible to get much faster. Can I please ask what the fastest speeds you all get is? I am thinking about getting a directional antenna to boost signal in hopes of getting over 100mbps. So. What do you guys get? Thanks.
Bailey
  • Fastest live network peak DL speeds with MR1100 EU I have seen is about 720 - 740 Mbps.
    • baileyrhood90's avatar
      baileyrhood90
      Tutor
      WoW. That is incredible. I am just trying to get to 100mbps and I'll be happy.
      • JSchnee21's avatar
        JSchnee21
        Virtuoso
        Hi baileyrhood90,
        Yeah, TeeJay always posts some amazing speeds but he has the European version and gets those speeds in Finland/Sweden? (I forget).
        Here in the USA, using my US branded MR1100 from AT&T, I have never gotten above 110Mbit and have never seen a post here or on HowardForums from anyone who has done better.  This is on my AT&T Unlimited plan (Plus / Premier / Platinum -- whatever they call it).
        In contrast my new iPhone XS Max -- which has the worlds worse reception -- routinely gets 130-240 Mbit when I'm near upgraded towers in PA.
        To be fair, I don't use the Ethernet connection (nor USB) on my MR1100 very often.  All of my speed testing has been over 5.8GHz Wifi @ 40Mhz bandwidth.  I've tried 80MHz as well -- but it was usually worse -- probably due to interfering bands.
        I strongly suspect something is amis with the US version of the MR1100.  Looking at the FCC filing information I suspect its using some really old QAM protocols.  Or the CA or MIMO are screewed up.  not sure.
        Of course no one from Netgear ever responds to this forum -- unlike their Router forums.
