Jacobguest2016
Jan 22, 2019Follower
Nighthawk M1 (MR1100) MR1100 MYMEDIA upload file fail
MR1100’s MYMEDIA cannot update file to SD SIM on latest firmware NTG9X50C_12.04.02.00.
After I start to update file, the process would been queued. But the session would hold and then no response ...
Blanca_O
Jan 29, 2019NETGEAR Employee Retired
Welcome to NETGEAR Community!
- May we please know the SD card file system format used? Capacity?
- Is it the same behavior when you download a file?
- What is the model number of your device?
Blanca
Community Team
- Blanca_OFeb 03, 2019NETGEAR Employee Retired
This has been brought up already to engineers. I will get back to you guys for any updates.
Blanca
Community Team
