netsolutions
Feb 28, 2019Aspirant
Nighthawk M1 MR1100 on Linux OS?
Will the Nighthawk M1 work with a Linux operating system such as Ubuntu?
If so, are there any limitations on use?
- Retired_MemberMar 01, 2019
The MR1100 has no installation requirements and it can be used with any OS by accessing the dashboard through most web browsers.
As Firefox is the standard web browser supplied with Ubuntu, you should be able to access and manage the MR1100 though its default ip 192.168.1.1/
Personal use with Linux Mint (ubuntu derivative) MacOS and Windows; Firefox, Safari and Edge after initial setup with own admin password has been good - though Safari restore from backup has limitations.
hyppolyte
1 Reply
- Retired_Member
hyppolyte
