ynateil
Jul 17, 2019Aspirant
nighthawk m1 MR1100 OOREDOO only works when plugged in without a battery
The router would only turn on when its plugged in into an outlet without a battery. When I plug it in with a battery, the led will start flashing blue and red light and the screen will have a low bat...
Blanca_O
Jul 30, 2019NETGEAR Employee Retired
Hi ynateil
Welcome to NETGEAR Community!
I suggest that you contact OOREDOO to do a hardware check and if device needs replacement.
Blanca
Community Team
ynateil
Aug 01, 2019Aspirant
There’s nothing wrong with the hardware and the device is fine. The only issue is the battery, I literally had this device for 1 year and the battery just became corrupt. It won’t start up at all with my battery, unlike with my friends battery. It worked perfectly fine and was charging. So I’m really confused now how can a battery become corrupt like that within 1 year.
