krisdev25
Dec 15, 2020Tutor
Nighthawk M1 MR1100 will not connect with Keepgo data only SIM
For some reason I am getting a "Mobile Broadband Disconnected" when using a Keepgo data only SIM. I can see that the Netgear Nighthawk M1 (MR1100) uses the AT&T tower. However, it will not allow me...
krisdev25
Dec 16, 2020Tutor
Where can I download the non-AT&T firmware to install on the device manually?
krisdev25
Dec 16, 2020Tutor
The manual option for updating the firmware is not enabled. It is blocked. Can I perform manual update using the command line or another method?
- TL_NTGRDec 16, 2020Apprentice
If your M1 model is one that allows local upgrades, then the firmware is on the support.netgear.com site. But if it truely is the AT&T version, then only upgrade option is via AT&T FOTA (Firmware Over the Air) servers.
Can you log into your device, once logged in, put this in the browser (http://192.168.1.1/model.json) and save the output to notepad and attached here?
- krisdev25Dec 16, 2020Tutor
Sure, I have uploaded the model.json file below. This blog will not allow me to attach JSON or TXT files, so PDF.
This router is not bound by AT&T. I mean it has been paid for and the contract period has been upheld and has since ended. Therefore, this device is no longer bound to AT&T.
Can I enable the firmware update through a REST API and send JSON data to change this setting to update the firmware.
Otherwise, is there a command line tool from Netgear to connect to the device and update the firmware, to a generic Netgear firmware instead of AT&T firmware? This is my wish.
Here are the instructions for a non-AT&T branded unit (but manual option not available):
I've also tried with TFTP with the command below, but not getting error:
C:\Users\krzys\Downloads\MR1100NAS_V12.06.11.00_00>tftp -i 192.168.1.1 put MR1100-100NAS_23113828_NTG9x50C_12.06.11.00_00_GenericNA_05.03.secc.spk Connect request failed C:\Users\krzys\Downloads\MR1100NAS_V12.06.11.00_00>
Need to find another way.
