HimalayAir
Dec 04, 2020Follower
Nighthawk M1 MR1100 won't connect with Yale Smart Home Hub
I've bought the M1 specifically to allow me to use a Yale Smart Home alarm system on a property with no cabled broadband connection. The Yale Hub has to be connected to the router via Ethernet, not ...
W1lliam
Dec 08, 2020Virtuoso
you can try to insert another Ethernet Switching HUB, any brand should do the work, between M1 and Yale Hub. Sometimes just hardware interoperability problem.
William
