Teewee4134
Apr 07, 2018Guide
Nighthawk M1 (MR1100)
I will like to compare and share my Nighthawk MR1100 Routers experience. Location Kuwait I owned two Unlock Nighthawk hotspot routers (MR100), one from Australia (Telstra) and USA (att). Both have ...
newbie3
Jul 05, 2018Aspirant
I use this router in the Philippines.
With the ISP Smart it works out of the box, the remaining traffic is displayed and the speed goes up to 50 Mbit which is good.
However, with Globe it doesn't work. On the control panel it also doesn't show a service number. No connection can be established. I tried it with 3 different SIM cards.
Since I mainly bought this router because of Globe it makes it quite useless for me.
Is there any solution for this?
Blanca_O
Aug 05, 2018NETGEAR Employee Retired
Hi newbie3,
Did you configure APN settings for the said ISP?
Blanca
Community Team
