turbolooser
Jun 10, 2020Aspirant
Nighthawk M1 (MR1100EUS) DMZ not working on latest firmware (again)
I am just pasting my previous issue repot as its the same again...DMZ not working...and even worse no port forwarding at all
Could you please check again.
firmware: 12.06.12.00
Thanks
Thomas
Dear Netgear Support and others trying to help :-)
I am running the MR1100 with a public ipv4 address associated to a dyndns record but DMZ enabled does not allow any access on any service hosted behind the MR1100. When enabling a single port in port forwarding (e.g. port tcp 22) then I can access that 1 service from external but this is not the intention when using a DMZ.
I have already reset the device once using the webui but might wanna do it again using the hardware button.
Any other ideas?
And please note that I am IT professional so do not botehr me with the usual "Hav you tried to turn it off and on again" replies.
Thanks so much
Thomas
- turbolooserAspirant
noone else having this DMZ issue even with the latest firmware?
- Macke4EverAspirant
I have same issues. DMZ does not work.
Firmware NTG9X50C_12.06.12.00
