Darcko
Oct 19, 2020Aspirant
Nighthawk m1 no connection
I have a nighthawk m1 router, i can't connect to it. The wifi doesn't show up on any device (laptop, phone) Ethernet to the laptop does not work ( network cable unplugged) USB connection also doesn...
Blanca_O
Oct 19, 2020NETGEAR Employee Retired
Hi Darcko
Welcome to NETGEAR Community!
Kindly do a factory reset using the Reset button. Press and hold the Reset button for five seconds. The mobile router returns to factory settings.
Was this working before?
If so, what happen prior the issue occur?
Blanca
Community Team
- DarckoOct 20, 2020AspirantThanks for your reply.
The last thing i did was using the router with a different sim card (meaning another carrier) and it was connected, but one day it just wouldn't accept any sim card.
Yes i did a reset oh so many times.... After factory reset it just stayes the same with my original post..
I believe there is problem with framware but i can't connect to it to download a new patch- Blanca_OOct 23, 2020NETGEAR Employee Retired
Hi Darcko
You have to contact support team. This might be a hardware issue. Check the warranty of your unit and have it replaced.
Support team: http://www.netgear.com/support/contact.aspx
Blanca
Community Team- DarckoOct 23, 2020AspirantYeah i was afraid that's what going on, anyway the warranty is expired, must find a local repair shop.
Thanks for everything i really appreciate it
