Darcko
Oct 19, 2020Aspirant
Nighthawk m1 no connection
I have a nighthawk m1 router, i can't connect to it. The wifi doesn't show up on any device (laptop, phone) Ethernet to the laptop does not work ( network cable unplugged) USB connection also doesn...
Darcko
Oct 20, 2020Aspirant
Thanks for your reply.
The last thing i did was using the router with a different sim card (meaning another carrier) and it was connected, but one day it just wouldn't accept any sim card.
Yes i did a reset oh so many times.... After factory reset it just stayes the same with my original post..
I believe there is problem with framware but i can't connect to it to download a new patch
Blanca_O
Oct 23, 2020NETGEAR Employee Retired
Hi Darcko
You have to contact support team. This might be a hardware issue. Check the warranty of your unit and have it replaced.
Support team: http://www.netgear.com/support/contact.aspx
Blanca
Community Team
- DarckoOct 23, 2020AspirantYeah i was afraid that's what going on, anyway the warranty is expired, must find a local repair shop.
Thanks for everything i really appreciate it
