Rickrock
Apr 29, 2020Follower
Nighthawk M1 not supported by netgear Mobile App??
I'm trying to connect my Nighthawk to the mobile app but the message on the mobile app says Sorry, this mobile Router is not supported by the netgear mobile app. I've re installed the app, but s...
michaelkenward
Apr 30, 2020Guru - Experienced User
Rickrock wrote:
I've re installed the app, but still no go
Probably because the message is correct.
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
- minskuApr 30, 2020Aspirant
michaelkenward Op was not asking about the Nighthawk app but the Mobile app that is supposed to work with M1. Having the very same issue here.
- michaelkenwardApr 30, 2020Guru - Experienced User
So why post in the section for the Nighthawk app if that wasn't what they meant?
You might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
