Rickrock
Apr 29, 2020Follower
Nighthawk M1 not supported by netgear Mobile App??
I'm trying to connect my Nighthawk to the mobile app but the message on the mobile app says Sorry, this mobile Router is not supported by the netgear mobile app. I've re installed the app, but s...
Ksa3344
Aug 31, 2020Apprentice
It didn't work with me when i changed its IP from 192.168.1.1to 192.168.10.1 .
It works again when i returned it to its default IP , so make sure you haven't changed it and it should work fine .
