S36
Feb 26, 2020Follower
Nighthawk M1 NTG9X50C_12.05.05.14 Firmware Issues
My Nighthawk was functionion perfectly fine, AT&T pushed this NTG9X50C_12.05.05.14 firmware update, and now it's nothing but disconnects; several a minute at times. This is unbelievable. I've al...
JohnPeng
Feb 28, 2020NETGEAR Expert
I've already factory reset the device, yet continue to have these issues where the internet stalls, or the device is frantically connecting to different bands and ultimately loses "connected" status. My signal is "Good" LTE. Before the update, I would constantly get 80-95 Mbps down/ 45-50 Mbps Up and NO disconnects when it'd utilize B2 band.
What can I expect?
Please follow the steps below to capture the log for debugging.
Step 1: Open 192.168.1.1 on your browser.
Step 2: Input the account and password if necessary (admin/password)
Step 3: type 192.168.1.1/model.json
Step 4: Select everything (Ctrl + A), then copy-paste it into a text file.
Step 5: Save the text file as model.json_log.txt
Step 6: Submit the Log file
Thanks
