EMITE_Ing's avatar
EMITE_Ing
Follower
Dec 11, 2017
Nighthawk M1. Only 3 Component Carriers (CC) supported and up to 4 in technical specs
Dear all.
We purchased a Nighthawk M1 (MR1100) a few months ago in Australia. We can see in the technical specifications of the product, that up to 4 Component Carriers are available. Also in below discussion said that a maximum of 5 component carriers can be aggregate:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Nighthawk-M1-Up-to-4X-Carrier-Aggregation-how-to/m-p/1284199#M2341
But we have a Base Station Emulator (CMW500) and we realized that only can have up to 3 component carriers available for the M1. For example, following bands configuration is allowed: Band7 (4x4) + Band7 (4x4) + Band3 (2x2).
We have checked, in Downloads section, if there is a new firmware for the M1 but it is not any available (we get this message: Firmware/Software not available for this model)
We have two questions:
Q1. Could you confirm to us if 4 component carriers LTE-CarrierAggregation are available for the M1?
Q2. If answer to previous question is yes, could you tell us which bands configuration using 4 component carriers LTE-CA are allowed for the M1?
Thank you in advance,
Best Regards,
EMITE Ing.
  • According to the M1 specifications published on page 87 of the manual, it only supports 3 x CA the following frequency combinations are supported 1800+700, 1800+2600, 2600+700, 2600+2600, 700+1800+2600, 1800+2600+2600, 700+2600+2600 MHz
