asolepascual
Apr 06, 2021Aspirant
Nighthawk M1 or M2 extern supply
Can the Nighthawk M2 or M1 work without an inserted battery and as a fixed router? In other words, operate connected only to the power supply. Thank you.
michaelkenward
Apr 12, 2021Guru - Experienced User
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
The manual for the MR2100 says:
Your mobile router can receive power from any of the following sources:
- Rechargeable battery included with the mobile router
- Wall socket using the AC adapter and USB cable
- USB port on your computer
I leave it to you to read the other manuals.
