v5_rnas's avatar
v5_rnas
Nighthawk M1 Passthrough Mode
After enabling IP passthrough mode is it still possible to view the M1 admin screens? If so which IP and subnet would be used to do this.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Aug 13, 2017
    It's found under Settings > Setup > Router Setup.
    A firmware update (NTG9X50C_10.16.04.04) was recently released. I'm running that (I can't remember if this feature was available in older firmware).
    If not already running it you may wish to update to this.
    Note after the update you may need to clear your web browser cache (e.g. Temporary Internet Files in Internet Explorer) for the Dashboard to display properly.
