dastrix
Apr 17, 2019Aspirant
Nighthawk M1 Passthrough Mode
Hi All,
I believe the M1 supports passthrough. Am I right in saying that when setup, the dynamically assigned IP from the telstra carrier in this case, would be allocated to the DHCP Client int...
W1lliam
Apr 18, 2019Virtuoso
When doing IP Passthrough, the host connected to M1 would be assigned with IP address dyanmically as private address (from M1), not the one from carrier.
William
- dastrixApr 18, 2019Aspirant
So if the host is a pfsense firewall, does that mean the public IP is not allocated to the firewall? if its a bridge, which is layer 2, where is the public ip allocated to?
- W1lliamApr 18, 2019Virtuoso
The public IP is assigned to M1's WAN interface all the time.
William
Right, so its not a bridge as the device would still then be doing NAT, is there no way to run it in Layer 2 mode only?
Is there a device that is more suited, ie a 4G LTE modem that operates as a proper layer 2 bridge?
