LorettaS
Feb 14, 2021Follower
Nighthawk M1 password nothing works
cannot login on my iPad to the Netgear Nighthawk Mobile app. Will not accept the router password or "admin" that is suggested by system. It will not take anything I try to put in.
michaelkenward
Feb 15, 2021Guru - Experienced User
The M1 is actually the Netgear Model MR1100.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
