Woolaorc's avatar
Woolaorc
Initiate
Oct 29, 2019
Nighthawk M1 Port Forward Error
Brief setup overview:
I have my M1 setup with DMZ with the IP 192.168.1.22 being sent to my router. My router has picke this up as the WAN address.
I've enabled Port Forwarding but when I try to add a port to the list I get the message ""error adding entry". I've tried the following destination addresses and none work
192.168.1.22 (what I think it should be)
192.168.1.1 M1 default gateway
192.168.0.1 Router default gateway.
Same error not matter the port or protocol type.
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Woolaorc
    Welcome to NETGEAR Community!
    Please describe your network setup. How did you setup the MR1100?
    Blanca
    Community Team
