alexkeogh
Apr 04, 2020Follower
Nighthawk M1 Problem
Hi, Im having a bit of a problem. I live rurally so I have bought the M1 to replace my fixed line broadband. I was hoping that it would simply replace my static router, which I could then connect...
RVALENZ
Jul 07, 2020NETGEAR Employee Retired
Hello, Alex, Do you still have issues with the M1?
If you connect to the M1 without the AP via WiFI, What is the speed that you get?
What are the devices that are connecting to the WiFI network?
-Rhys
