Joyce88's avatar
Joyce88
Nighthawk M1 roaming won't work APN settings Portugal
Hi hoope someone can help . I am getting extremely cross. Trying tio get roaming working in Portugal but need APN settings for Portugal carrier MEO , Nos , perhaps vodaphone. Sim works in a phone but router no . can even get intoi the mobile app now.
Suggestions of what to do where to look would be appreciated as it is ruining my trip Nighthawk M1
Thanks
joyce
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    On the APN setting page, please check Roaming data to enable it. Then the device will be able to connect to roaming network automatically.
    Thanks
    • Joyce88's avatar
      Joyce88
      Hi thanks for response unfortiunately did not work with this sim. Another sim did work. My internet supplier seems incapable of providing me with APN settings and I don't know where to find them for Bouyages France
      • JohnPeng's avatar
        JohnPeng
        NETGEAR Expert
        If your APN setting is the same as what you used in your home network, but data connection still can not be set up after you enable Roaming data checkbox, that means your SIM plan may not have roaming data enabled. Please check your carrier.
        If you buy a local SIM card, you can ask the vendor what APN to set.
        Thanks
