mozzzie
May 18, 2020Aspirant
Nighthawk M1 set up as access point
Hi all,
I'd like to set my Nighthawk M1 up as an access point to my existing network. No SIM card. I'd like to connect wirelessly from an area where my existing wifi signal is weak, so I thought I'd connect the Nighthawk via ethernet over power to my main router.
Has anyone done this? Is it possible? What configuration should I use?
Many thanks.
mozzzie
You might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.- mozzzieAspirant
Thanks I will repost.
