Pt1936
May 25, 2023Tutor
Nighthawk m1 shuts down
Using in a motorhome in storage off 5v usb supply. After about 4 days unit shuts down. Only way to restart is to remove battery then attach to power. Unit only a few months old. Battery is fully cha...
May 25, 2023Guru - Experienced User
If you have it on constant ac power, it shouldn't have the battery in it.
- Pt1936May 25, 2023Tutor
Is that also the case for constant dc power? It’s in a motorhome, plugged into a usb power supply. I’ll try it without the battery.
- plemansMay 26, 2023Guru - Experienced User
The power supply converts to DC power anyway.
- Pt1936May 26, 2023TutorHi. Yes I’m aware of that, but there isn’t a 240v supply in the motorhome, works off solar and 12v batteries. I’ve plugged it into usb without battery. See what happens. Thanks
