Pt1936
May 25, 2023Tutor
Nighthawk m1 shuts down
Using in a motorhome in storage off 5v usb supply. After about 4 days unit shuts down. Only way to restart is to remove battery then attach to power. Unit only a few months old. Battery is fully cha...
May 25, 2023Guru - Experienced User
If you have it on constant ac power, it shouldn't have the battery in it.
Pt1936
May 25, 2023Tutor
Is that also the case for constant dc power? It’s in a motorhome, plugged into a usb power supply. I’ll try it without the battery.
- plemansMay 26, 2023Guru - Experienced User
The power supply converts to DC power anyway.
- Pt1936May 26, 2023TutorHi. Yes I’m aware of that, but there isn’t a 240v supply in the motorhome, works off solar and 12v batteries. I’ve plugged it into usb without battery. See what happens. Thanks
- Pt1936Jun 02, 2023Tutor
Seems to be ok plugged into usb power supply once battery removed. I had a different mifi unit in previously, that worked with battery in when left permanently plugged into usb. Thanks for your suggestion, I would not have thought about removing the battery as seems unusual!
