timmyd1924
Aug 23, 2019Follower
Nighthawk M1 Sim not Installed
I have a nighthawk m1 m1100. It is unlocked, I used a code to unlock it when I purchsed it. It worked fine for about a month then was having issues so I reset it. I think that may have relocked it...
- Aug 29, 2019
Hi timmyd1924
Welcome to NETGEAR Community!
Please ensure that the SIM card is active and enabled with data services. If you have another SIM card, kindly use that to check if you still get the same message.
Blanca
Community Team
Blanca_O
Aug 29, 2019NETGEAR Employee Retired
Hi timmyd1924
Blanca
Community Team
