NeilCroft91
Apr 21, 2020Tutor
Nighthawk M1 Switched to 2.4ghz from 5ghz
Can someone please help me with my night hawk m1..... I have accidentally switched from 2.4ghz to 5ghz on my mobile app, however my phone cannot find it now, and i cannot connect to tje app without being connected to the router.... PLEASE HELP ASAP thanks
1 Reply
- JohnPengNETGEAR Expert
Please do a factory reset.
Or you can connect the device to your computer using USB cable and connect to WebUI to change the WiFi setting to dual band again.
Thanks
