RobGi
Feb 13, 2025Aspirant
NightHawk M1 unresponsive
Hi All, I'm hoping someone can help me repair my rather expensive Nighthawk M1 shaped illuminated coaster. It is powering up fine and telling me to connect via wifi however there is no wifi n...
RobGi
Feb 17, 2025Aspirant
Hi,
Thx for the response.
I purchased the device in 2019.
I only use it occasionally when I am on holiday or my broadband goes down.
I was tryting to use the router in thethered mode via the USB port.
My router is the MR1100-100.
After loosing connectivity I performed a system reset to put it back to default settings in case it was something I had done.
The router seems to boot up and display all the correct info indicating the router requires configuring.
I have tried connecting to the router via wifi, ethernet, and USB.
It seems to boot fine and provides me the Wifi network name and code, but it is not detected by my phone or laptop.
My PC fails to obtain an IP via the Ethernet port when connected.
If I connect via the USB my PC bings to acknowledge the device is detected but nothing else seems to happen.
The router is unlocked so not tied to any carrier.
rcpax
Feb 17, 2025Luminary
do you think your device might have actual connectivity issues with the carrier?
most of the time, is is an issue with the carrier settings or the carrier itself blocking sim cards from these devices. just a thought.
at the very basic settings, when you have actual working connectivity with the carrier, the usb tether should work unless it was set as turned OFF. the mobile router should give you a local working IP. first test i would do after reset is try to reach the router admin page. usually 192.168.1.1 after a full factory reset. can your mobile router do that?
- RobGiFeb 18, 2025Aspirant
This is what I tried.
I performed a factory reset and after that whether I connect via USB or Ethernet I do not get a connection to the router.
The ethernet port won't come up and the wifi network can't be found either.
- rcpaxFeb 18, 2025Luminary
sounds like a hardware issue. i'd say this problem should be terminal if it's indeed hardware. i was going to suggest a reflash of firmware, but since you can't even get into the admin page, there seems to be no other option for your device.
