meloserj's avatar
meloserj
NightHawk M1 wall mount
Hello mates
I am looking for a compatible wall mount for my Nighthawk M1.
I did search based on the Dimensions: 105.5 (L) x 105.5 (W) x 20.35 (H) mm but couldn't find proper compatible device.
I also tried wall mounts for apple TV like Innovelis TotalMount pro or reliamount but seems they won't fit.
Any suggestion will help me to choose the correct one.
Thanks a lot
Cheers
