PinoF's avatar
PinoF
Nighthawk M1 wifi overlays the source
Hi there !! I got this problem, I just bought an M1 and I'm testing it at home before use it, the final scope is to use it in some events to create a personal wifi network and manage some different tools connection, i connected the M1 via ethernet to my home router and is perfectly working I can navigate and send files through the devices, my problem is that when the M1 is connected the home wifi connection stops working, is there a way to manage this thing from the M1 ?
thanks
1 Reply
  • solved changing the internal ip range
