Whodo
Oct 28, 2019Guide
Nighthawk M1 WiFi sporadically disconnects - Part 2
This is a follow-up to the topic Nighthawk M1 WiFi sporadically disconnects. After working with tech support, it was determined that my hardware was defective so a replacement was sent (for the cost ...
Whodo
Nov 04, 2019Guide
It has been one week since I updated the firmware. There have been no WiFi disconnects since. The firmware update appears to have resolved the sporadic disconnect problem seen with the previous version of firmware.
~ Varan
Viewpoint
Nov 06, 2019Aspirant
Having a similar issue immedately after updating to the newest 12.06.08 firmware. It has not resolved yet. It's not the network. I can take the sim out and use in another device, it works great, put it back in the MR1100 and it drops internet after a few minutes even though it shows connected in the dashboard.
- WhodoNov 12, 2019Guide
Thanks for the warning. This update appeared on my M1, but I did not install it, nor will I. I have had zero disconnects since updating to 12.06.07.
