ContiGT's avatar
ContiGT
Nighthawk M1 won't power up with battery removed - powered with Qualcom4+ by Belkin
Hi folks. I have recently purchased this refurbished router and want to power it 24/7 and am using a Belkin Qualcom Q4+ power module ( backward compatible to Q2) but when I remove the battery it won'...
  • ContiGT's avatar
    Jun 02, 2020
    Found the problem myself! Wasn't  a 'real' problem after all! The Belkin power pack is a multi voltage charger and relies on a "sense voltage" to fire it up - no battery, no voltage detected, no charger output! So a dedicated Q3 5volt 2.4amp charger purchased. Problem solved!
