LRFloyd
Jun 03, 2020Aspirant
Nighthawk M1 working on T-mobile hotspot data plan?
I found a reseller of T-mobiles new data only plan that I believe will skip the professional install normally required. Seller say's incompatible with Nighthawk M1.. Why would that be?
Blanca_O
Jun 08, 2020NETGEAR Employee Retired
Hi LRFloyd
Welcome to NETGEAR Community!
MR1100 will work with T-Mobile as long as it uses the right data plan which is for Mobile Hotspot.
Blanca
Community Team
LRFloyd
Jun 09, 2020Aspirant
Is there any way you can point me to the plan that would work? can i post a link to an ebay seller?
