LaurentG
Mar 09, 2021Aspirant
nighthawk M1 wrong DNS for Guest network ?bug?
Hi, I have the following lan setup for my router: IP 172.102.4.1/24 DNS 172.102.4.253 DHCP enabled When devices connect to 2.4 or 5 GHz WiFi they get the correct IP and DNS. When devices...
schumaku
Mar 09, 2021Guru - Experienced User
Reads like a bug. What exact M1 model variant and firmware version in involved? However, it's possible that there is a DNS relay or proxy on the device. Does the .1 address not resolve DNS queries?
PS. Have requested moving your thread to the Mobile Routers, Hotspots & Modems community section Blanca_O should be able to carry this ahead.
- LaurentGMar 09, 2021Aspirant
Hi,
The model is MR1100-100, and the firmware is
Also find attached a backup of my config. It is a lab infra so there is no problem with sensitive data.
I made additional tests and I realize that there's a DHCP relay for non-Guest WiFi, but for Guest the router will distribute an address from its own DHCP table. Only thing is that the DNS distributed is wrong.
Let me know if you need something more,
BR,
Laurent.
Now the firmware screenshot as a file
- schumakuMar 09, 2021Guru - Experienced User
Quickly tested (never use the Guest network, but sometimes relocating the router to a high address) - appears they push in the .1 for DNS on the guest network DHCP regardless. Clearly a bug.
Beyond, afraid, I'm not Netgear and we need Blanca_O or another NTGR rep here.
