KV01
Aug 08, 2017Follower
Nighthawk M1
Just upgraded firmware and being asked if I want to upload the upgrade to my hard drive. Should I do this and if so, where should I save It? I'm not a tech person. Personal user live in rural area o...
mdgm-ntgr
Aug 13, 2017NETGEAR Employee Retired
What I'm seeing is "Use upgrade file on your hard disk" option which would mean that you could upload manually a firmware image provided by Telstra onto the router rather than doing an OTA (Over The Air) update.
This is not downloading an image from the M1 onto your PC but the opposite, installing a firmware image from your hard drive onto the M1.
Is this what you're seeing or are you referring to something else?
Do you have good LTE coverage in your area?
