Nightwho's avatar
Nightwho
Nighthawk M1
I tried to update the new firmware for a friends, who has the Nighthawk M1 Mobile Router.
To my surprise,the update didn’t download. The text box said “ Update Error ,The update couldn’t be updated and the mobile router will automatically re-check for an available update within 48 hrs “
Can you tell me what’s happening with this new firmware  not being able to download.
I did the manual update but this also came up with a error.
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please advise your device's SKU and FW/PRI versions.
    Thanks
    • Nightwho's avatar
      Nightwho
      Hi John,
      Nighthawk M1
      SKU MR1100_1TLAUS
      Firmware NTG9x50C_12.06.02.00
      Thanks
      Nightwho
    • Nightwho's avatar
      Nightwho
      Hi John,
      The new firmware I’m trying to download is Version 12.06.08.00
      Regards
      Nightwho
      • JohnPeng's avatar
        JohnPeng
        NETGEAR Expert
        Please do a factory reset and try agaon.
        Thanks
