Coorslight67's avatar
Coorslight67
Follower
Feb 10, 2020
Nighthawk M1
Hi, I have a nighthawk M1 and I wanted to boost my signal, so I bought a lte wifi antenna and I bought bingfu external pigtail TS9 to use in the external antenna ports on my M1, when I plug them in, I notice I loose connectivity and the bars for my signal go down to 1 bar on the M1, am I missing something or is this normal, did not think I would lose connection when plugging in the pigtail to the M1. Any help would be greatly appreciated, thank you.
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    The antenna ports on the device for connect extranl LTE antenna. There is no connection for external WiFi antenna.
    Thanks
