dabonz413
Jul 13, 2020Follower
Nighthawk M1
Dear support: I am using a Nighthawk MR1100 (firmware NTG9X50C_12.05.05.14) and am having an odd problem. The mobile router will suddenly stop allowing the internet connection to devices. The ro...
icaruspony
Jul 26, 2020Luminary
I think I know what is happening. It happened to me, and I figured it out with a little investigating.
Let the problem return (where the connection is not working). DO NOT REBOOT OR FIX IT. While the problem is still present, do the following tests:
1. Can you ping, still? (yes/no)
ping portquiz.net
2. Can you access portquiz.net on port 80? (yes/no)
3. Can you access portquiz.net on port 443? (yes/no)
4. Can you access portquiz.net on port 666? (yes/no)
5. Which VPN were you using that worked? ______________________
6. What port # do you connect to this VPN server on? _______
7. Are you on an AT&T Connect Car Plan or an AT&T Ipad plan? _______
This will help you figure things out. I suspect you will be able to ping and will be able to connect to 666, but you will not have connectivity to 80 or 443, and I suspect your VPN is not using 80 or 443.
