dabonz413
Jul 13, 2020Follower
Nighthawk M1
Dear support: I am using a Nighthawk MR1100 (firmware NTG9X50C_12.05.05.14) and am having an odd problem. The mobile router will suddenly stop allowing the internet connection to devices. The ro...
icaruspony
Jul 27, 2020Luminary
DNS is not the problem.
He said he could not connect to a web server by its IP address: http://212.129.20.209/
DNS is used to look up IP addresses using its friendly name (such as www.google.com). But if you specify the IP address in the address bar, this bypasses DNS completely. There is no "friendly name" that needs to be converted to an IP address.
DNS is like a phone book. You can look up a person's NAME to find out their PHONE NUMBER. But if you already know the phone number, why do you need the phone book? Even if your phone book was damaged, you'd still be able to dial the phone number that you already knew.
W1lliam
Jul 27, 2020Virtuoso
Yes, wan't noticed that, you are right about this.
