mikecunn11
Aug 19, 2020Follower
NIGHTHAWK m1
Hi thank you, I just purchased an Nighthawk M1, I have to wire an Ethernet Cat 5 cable to my hub. The wire can either be T-568A or T568-B. Can you tell me which way the Ethernet port is wired on my n...
icaruspony
Sep 02, 2020Luminary
Normal. Does not use "crossover" cable.
