Bleck88
Sep 30, 2020Follower
Nighthawk M1
I recently bought the nighthawk M1 hotspot to use as my main home internet since the only available option is extremely slow. I noticed after I got it set up that the speed was much faster than my cur...
Blanca_O
Dec 28, 2020NETGEAR Employee Retired
Hi Bleck88,
Welcome to NETGEAR Community!
Please provide the device SKU (e.g. MR1100-100NAS). This can be checked on the box of the product or on the barcode label.
If issue re-occur, kindly check the signal strength and network type (for example, LTE 4G is generally faster than 3G). If the network signal is low, consider using external antennas or cradle the mobile router with built-in high-gain antennas.
Blanca
Community Team
