UdoK's avatar
UdoK
Follower
Oct 18, 2021
Nighthawk M1
The display of my Nighthawk M1 shows an icon/symbol consisting of a battery and three wavesymbols (like an "S") which are rising from the battery. Where can I find the meaning of this (and more) icons? Thanks for any help.
UDO
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    The icon means the battery is too hot and charging may be slowed down.
    If you use the device heavily with high speed download, you can consider to use the device without battery.
    Thanks
