SuperCrewBear
Feb 20, 2022Tutor
Nighthawk M1100 as modem with Netgear AC1750 router
I've been using a Nighthawk M1100 (AT&T) with a Netgear AC1750 router for a few months and it's worked pretty well. My problem is when browsing web pages that I often get an error saying a page can'...
Feb 20, 2022Guru - Experienced User
AC1750 is a speed. what router do you have?
What firmware is on it?
Is the AC1750 in access point mode?
or the M1100 in passthrough mode?
SuperCrewBear
Feb 21, 2022Tutor
The firmware version is V1.0.4.122_10.0.95 (I just updated it before starting the reply...it had been V1.0.4.120_10.0.91). The M1100 is in passthrough mode but I don't know where to look about the R6400 being in access point mode or not. (R6400v2 - I only quickly looked last night and thought the modem model was an AC1750...) When I started (a couple months ago) both the R6400 and the M1100 had the same IP address - I changed the R6400 so that I'm able to access the settings for both. I'm not an expert at this stuff but I'm probaby a semi-advanced amateur. Ha Ha Thanks for your help!
