SarahJo
Sep 03, 2018Tutor
Nighthawk m1100 IP passthrough
I see many of us have the issue of the Nighthawk IP passthrough feature not working properly when connected to an external router via ethernet cable. The router works fine when connected to the night...
TeeJay74
Sep 03, 2018Virtuoso
I have MR1100-100EUS and bridge mode with wifi router works perfectly.
SarahJo
Sep 03, 2018Tutor
Do you know if the bridge mode allows the vpn passthrough function to work? That is my main reason for wanting ip passthrough to work. I want to use a vpn service using the m1100 as my internet.
- TeeJay74Sep 03, 2018Virtuoso
Yes I know, just tested Cisco Anyconnect VPN and it works, when MR1100 in bridge mode.
- SarahJoSep 03, 2018Tutor
I do not have a "bridge mode" setting. From what I can tell the settiing for IP passthrough is bridge mode, how did you get yours to work?
Here is how I did it:
Tested and it works and this allows me to access M1's web management page from Wifi router side.
