Lasaa's avatar
Lasaa
Nighthawk M1100 Telstra Remote Desktop Connection
I have the M1 Nighthawk from Telstra and have set up port forwarding for RDC I have arranged for the Fixed Dynamic IP from Telstra However I can't seem to get it to connect Any help would be most ...
  • ArodiD's avatar
    ArodiD
    Dec 04, 2017
    Hi Lasaa,
    The IP address displayed under settings->network is the WAN IP address.  This is the address Telstra is assigning you.  You need to ask Telstra to provision telstra.extranet on your account.  Once that is done you then need to create an APN profile under Other->Cellular with telstra.extranet APN.  You may want to check this.
    ArodiD
