Hondall-
Jan 16, 2020Follower
Nighthawk M1100
Can you leave the charger in all the time without damaging the battery?
JohnPeng
Jan 16, 2020NETGEAR Expert
Please advise the device SKU. You can find it under the battery.
If you would like to use the device 7/24 with PA connected it, we suggest you to use the device without battery inersted. The device supports no battery operation. But there is a condition for doing. You have to use a Qiuck Charge PA with 1.8 or 2amp output.
I need to know the SKU name to determine whether the your device was shipped with such PA.
Thanks
- JardinSwinglerFeb 12, 2020Aspirant
Where can we purchase or get a quick charger w 1.8 or 2 amp that is compatible for the m1100 night hawk? Cuz I need to have it plugged in 24/7 since it is the only form of internet we have in this area.
- JohnPengFeb 13, 2020NETGEAR Expert
Please refer to the following community post.
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Quick-Charge-3-0-charger/m-p/1752936
Thanks
John
