naro
Aug 04, 2021Follower
Nighthawk M2 - Firmware Update Stuck
Hi, I've currently on firmware: NTGX24_10.17.08.00 with modem SDX24_10.25.00.06. Whenever I try to update the firmware via the physical device's GUI or via the webapp, it just hangs forever. ...
JohnPeng
Aug 12, 2021NETGEAR Expert
naro wrote:
Hi,
Whenever I try to update the firmware via the physical device's GUI or via the webapp, it just hangs forever. There appears to be no way of manually uploading firmware and I can't see if I'm on the latest firmware version.
Can you help?
Thanks.
Just checked. Your device is already on the latest release.
Thanks
John
- Jake74Aug 12, 2021Aspirant
If my modem is already on the latest firmware release, why can't I connect to the EE mobile network in the UK?
My EE sim card has perfect reception when in my mobile phone but it won't connect when it is in the MR2100 router?
thanks- JohnPengAug 12, 2021NETGEAR Expert
thanksUNfortunately, EE MR2100 is a carrier SKU. We can't push out the new update without EE approval.
Thanks
John
- Jake74Aug 13, 2021Aspirant
Thanks for responding John.
I have have now tried a Three 3 SIM card and the router will still not connect to the Three 3 network.
What network in the UK do you suggest I try. The router was working with EE and I entered into a contract with E on that basis. Besides, EE and Three, can you suggest another network in the UK?
Thanks in advance.
