naro
Aug 04, 2021Follower
Nighthawk M2 - Firmware Update Stuck
Hi, I've currently on firmware: NTGX24_10.17.08.00 with modem SDX24_10.25.00.06. Whenever I try to update the firmware via the physical device's GUI or via the webapp, it just hangs forever. ...
JohnPeng
Aug 12, 2021NETGEAR Expert
naro wrote:
Hi,
Whenever I try to update the firmware via the physical device's GUI or via the webapp, it just hangs forever. There appears to be no way of manually uploading firmware and I can't see if I'm on the latest firmware version.
Can you help?
Thanks.
Just checked. Your device is already on the latest release.
Thanks
John
Jake74
Aug 12, 2021Aspirant
If my modem is already on the latest firmware release, why can't I connect to the EE mobile network in the UK?
My EE sim card has perfect reception when in my mobile phone but it won't connect when it is in the MR2100 router?
thanks
