Ruttenseb
Aug 25, 2023Aspirant
Nighthawk M2 as backup-modem to my RBR863
I was wondering if it is possible to add my Nighthawk M2 Mifi router to an excisting lay-out as a sort of back-up when the 'landline' isnt working. current setup: Modem -wired connection- RBR...
Aug 25, 2023Guru - Experienced User
Sadly no. the 8 series doesn't support dual wan/failover. That's what you'd need to accomplish what you're trying
