skycam01
Jun 15, 2020Follower
Nighthawk M2 Bridge Mode or IP Pass Through
Hello, I am based in Australia and have a Telstra 4G Netgear Nighthawk M2 that I would like to be able to use as a modem that feeds an Internet Connection to a Ubiquit Edge Router X. I would ...
michaelkenward
Jun 15, 2020Guru - Experienced User
skycam01 wrote:
Is Bridge Mode or IP Pass Through an Option? Is there a software version that can facilitate this or is there a work-around.
Does Telstra have anything to say?
What does the manual for the MR2100 tell you?
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Things like IP Pass-Through Mode and Disable the DHCP Server Feature in the Mobile Router might be worth investigating.
But with luck someone who has done this will step in with some proper advice.
