Serendipite
Dec 05, 2021Follower
Nighthawk M2 disabled
My nighthawk m2 says WIFI Network is disabled but when I try to enable the screen comes up with WIFI Name Disabled and WIFI Password disabled and just continues to try and detect service...I am totall...
JohnPeng
Jan 03, 2022NETGEAR Expert
Did factory reset helping with your issue? What is the SKU name of your device and what is the FW version on it?
Thanks
John
- IYGEALJan 03, 2022AspirantIn my case factory reset hasn't helped. Model is AUS version (M21001TAUS), FW is 24.10.17.10. I made a detailed post on the other thread with 95 replies.
- JohnPengJan 03, 2022NETGEAR Expert
IYGEAL wrote:
In my case factory reset hasn't helped. Model is AUS version (M21001TAUS), FW is 24.10.17.10. I made a detailed post on the other thread with 95 replies.Can you log in to WebUI and enable ethernet offloading and do a FW upgrade check? There is a newer version available for your device.
FW: 10.19.03.00 and PRI 05.02
Thanks
John
Thanks
John
I just connected via USB. Data offloading failed to apply. It stuck at "Applying changes"
Also, Firmware Update is stuck at "Checking"
